BlackBerry made a very strong return in the year 2013, with two of its new flagship handsets, Q10 and Z10, seeking to re-seize the lost paradise. The specs of the beautifully crafted Z10 smart phone is on par with HTC One, Samsung S4 and iPhone 5, but whether or not this pivotal product can save BlackBerry’s future still remains unclear.  However, DVDFab DVD Ripper has already added support to rip DVDs to BlackBerry Z10 compatible videos, making it the first DVD ripper software doing so.
Check this tip to see the detailed procedure:
Convert DVDs for BlackBerry (Z10): Step 1 -> Download and install the latest DVDFab 9 onto your computer;
Convert DVDs for BlackBerry (Z10): Step 2 -> Launch DVDFab 9, choose Ripper option at the Option Interface (or from the Option Bar at the Main Interface), then load the DVD you are about to convert;
Convert DVDs for BlackBerry (Z10): Step 3 -> Select the movie title, audio track and subtitle stream you want to keep at the Operation Window, click the Profile Box (or Profile Icon) to find BlackBerry Z10 from Profile Library and press "OK" button, then just hit  “Start” button at the Main Interface to go converting.
Note: selecting BlackBerry (Z10) profile from the built-in Profile Library is the key point of the whole process.
Product you need order: DVD Ripper
For more information, just move on to DVDFab DVD Ripper page.
